- Joomla 1.0
- Ancienne branche
- Installation
- erreur lors de l'installation du site sur internet
Question erreur lors de l'installation du site sur internet
- cyprien24
01 Juil 2008 08:39 #1
par cyprien24
erreur lors de l'installation du site sur internet a été créé par cyprien24
impossible de passer l'étape 1 de l'installation sur internet, voici le message d'erreur qui s'affiche :
A database error occurred when running query
CREATE TABLE `jos_banner` ( `bid` int(11) NOT NULL auto_increment, `cid` int(11) NOT NULL default '0', `type` varchar(10) NOT NULL default 'banner', `name` varchar(50) NOT NULL default '', `imptotal` int(11) NOT NULL default '0', `impmade` int(11) NOT NULL default '0', `clicks` int(11) NOT NULL default '0', `imageurl` varchar(100) NOT NULL default '', `clickurl` varchar(200) NOT NULL default '', `date` datetime default NULL, `showBanner` tinyint(1) NOT NULL default '0', `checked_out` tinyint(1) NOT NULL default '0', `checked_out_time` datetime NOT NULL default '0000-00-00 00:00:00', `editor` varchar(50) default NULL, `custombannercode` text, PRIMARY KEY (`bid`), KEY `viewbanner` (`showBanner`) ) ENGINE=MyISAM DEFAULT CHARSET=latin1;
The error was:
You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near \'DEFAULT CHARSET=latin1\' at line 1 SQL=CREATE TABLE `jos_banner` ( `bid` int(11) NOT NULL auto_increment, `cid` int(11) NOT NULL default \'0\', `type` varchar(10) NOT NULL default \'banner\', `name` varchar(50) NOT NULL default \'\', `imptotal` int(11) NOT NULL default \'0\', `impmade` int(11) NOT NULL default \'0\', `clicks` int(11) NOT NULL default \'0\', `imageurl` varchar(100) NOT NULL default \'\', `clickurl` varchar(200) NOT NULL default \'\', `date` datetime default NULL, `showBanner` tinyint(1) NOT NULL default \'0\', `checked_out` tinyint(1) NOT NULL default \'0\', `checked_out_time` datetime NOT NULL default \'0000-00-00 00:00:00\', `editor` varchar(50) default NULL, `custombannercode` text, PRIMARY KEY (`bid`), KEY `viewbanner` (`showBanner`) ) ENGINE=MyISAM DEFAULT CHARSET=latin1;
quelqu'un peut il m'aider?
The error was:
- Joomla 1.0
- Ancienne branche
- Installation
Temps de génération de la page : 0.241 secondes
